My Question: If I use Fritzing and design a PCB, can I use my cheap 3020 CNC machine, which uses Mach 3 software to route a PCB. I could not see any instructions on Fritzing, (just downloaded it and not familiar with it)
Any help from you gurus would be very welcome.
Frank
Fritzing and CNC
Frank67227
#1
Stephen
#2
I’m not sure if Fritzing is compatible with that software, but what I do know is that you are probably better off using EAGLE to design a PCB. Fritzing is pretty limited when it comes to actual PCB design.
Frank67227
#3
Thanks Stephen,
I’ll just use Fritzing for the time being, my PCB’s won’t be that complicated
Frank
Graham
#4
Hi Frank,
There seems to be a way forward with the 3020 CNC Machine to mill PCBs, might be best to do a quick Google which may land you among others that have undertaken a project such as this one.
