This is a placeholder topic for “FT5330M - Aluminium Servo with metal horn (35kg/cm)” comments.
A seriously strong servo, perfect for large robots, RC cars, planes and anything that needs something moved.
Read moreThis is a placeholder topic for “FT5330M - Aluminium Servo with metal horn (35kg/cm)” comments.
Read moreHi,
I am just trying to intergrate a more powerful servo into my project without adding another power rail.
My question is can this servo be powered by a higher voltage, say 12V, and if not are there options that support such voltage ranges?
Hey @Job251805, welcome to the forums!
This servo has a maximum operating voltage of 7.4V so it most likely wouldn’t work running on 12V.
Have you considered using a step-down module to reduce your 12V rail down to something in the acceptable range for this servo (6 - 7.4V)?
Something like this may work for you:
Hope this helps! ![]()
Sam
