Hi Guys.
Pretty new to electronics like this, but reasonably familiar with automotive electronics.
I am looking at building a gear knob which has 2 x FSR’s front and back and using the output from these into a voltage divider to activate a 0-5v shift cut function in my programmable Engine ECU,
So every time i apply force to shift gear it will hopefully be sensitive enough to give me a clean signal my ecu can detect.
One of my questions is whether i can run the 2 x sensors i want to run in parallel into a single voltage divider. as i will only be using one FSR at a time depending which gear i am changing.
any help will be appreciated.
Andrew
