Just to save someone else the effort……here’s my code in MicroPython to run this on a Pico W.
When I say “my code” I mean Co-pilot’s code with a gazillion rewrites, error fixes, adjustments, clarification/modification/deletion of CP’s assumptions, explanations and explanatory notes.
The code will write both the register event and the IRQ event (when there is one) to the shell with each loop.
Requires the library file “DFRobot_AS3935_Lib.py” on the Pico.
I can image there’d be a LOT of tuning required to make this work in the field, spitting out reasonable data.
from machine import I2C, Pin
import time
from DFRobot_AS3935_Lib import DFRobot_AS3935
i2c = I2C(0, scl=Pin(1), sda=Pin(0), freq=100000)
SEN0290_ADDR = 0x03 # DFRobot AS3935 default I2C address
# AS3935 presence check (correct for SEN0290)
def startup_as3935_presence_check(sensor):
print("=== AS3935 Presence Check ===")
print("Expected I2C address: 0x{:02X}".format(SEN0290_ADDR))
try:
noise = sensor.getNoiseFloorLv1()
print("AS3935 responded correctly on I2C.")
print("Initial Noise Floor Level:", noise)
except Exception as e:
print("AS3935 did NOT respond:", e)
print("================================\n")
# AS3935 register sanity dump (only valid DFRobot getters)
def dump_as3935_registers(sensor):
print("=== AS3935 Register Sanity Check ===")
try:
wd = sensor.getWatchdogThreshold()
spike = sensor.getSpikeRejection()
print("AS3935 not responding:", e)
print("====================================\n")
return
print("Noise Floor Level: {}".format(noise))
print("Watchdog Threshold: {}".format(wd))
print("Spike Rejection: {}".format(spike))
# Sensor init
sensor = DFRobot_AS3935(i2c=i2c, address=SEN0290_ADDR)
sensor.reset()
sensor.powerUp()
time.sleep_ms(5) # allow oscillator + I2C interface to stabilise
sensor.setIndoors()
# ---------------------- Indoor tuning ----------------------
sensor.disturberDis() # disable disturber events indoors
sensor.setNoiseFloorLv1(4) # raise noise floor (0–7)
sensor.setWatchdogThreshold(2) # filter weak EMI (0–10)
sensor.setSpikeRejection(2) # filter short spikes (0–10)
sensor.setMinStrikes(1) # report lightning immediately
print("AS3935 ready (tuned for indoor use)\n")
# Perform diagnostics AFTER sensor is alive
# IRQ HANDLING
last_irq_event = 0 # 0 = none, 1 = noise, 2 = disturber, 3 = lightning
def irq_handler(pin):
global last_irq_event
last_irq_event = sensor.getInterruptSrc()
# IRQ pin on GP2
irq_pin = Pin(2, Pin.IN)
irq_pin.irq(trigger=Pin.IRQ_RISING, handler=irq_handler)
# EXTENDED TELEMETRY LOOP
while True:
# Timestamp
t = time.localtime()
timestamp = "%04d-%02d-%02d %02d:%02d:%02d" % (t[0], t[1], t[2], t[3], t[4], t[5])
# Read telemetry
irq = last_irq_event
dist = sensor.getLightningDistKm()
energy = sensor.getStrikeEnergyRaw()
# Extended telemetry line
print("%s IRQ:%d Distance:%s km Energy:%s Noise:%d" %
(timestamp, irq, dist, energy, noise))
# Separate lightning alert
if irq == 3:
print("%s *** LIGHTNING EVENT DETECTED! Distance:%s km Energy:%s ***" %
(timestamp, dist, energy))
# Clear stored IRQ so new events are visible
last_irq_event = 0
time.sleep(1)
