Help with ball tracking
Hello,
I have a small project at home to measure the speed and direction of a softball hit off a tee for my daughter so she knows where the ball went and how far by calculating the initial velocity and the direction with Raspberry Pi.
I have tried camera solutions but none of them provided reliable results. High speed camera with right exposure was needed but high speed cameras are too expensive that I cannot afford and the detection of a ball and the velocity was quite tricky when dealing with 3D space where the camera can only capture 2D surface.
I almost gave up my project after looking for a solution for months . Then I came across the product RD-03D radar. It looked very promising so I contacted core-electronics support, but I was told this radar sensor isn’t suitable for detecting high speed objects.
I was wondering if anyone has a good advice.
Hi Hisa
Golf teaching professionals use a similar device when analysing a student’s performance.
This seems to measure velocity, direction and spin direction and rate then predicts the flight of the ball for display on a screen. Probably measures other things too.
Some research might turn up how this all works and might give you some ideas.
Maybe worth a look.
Maybe I just wasn’t looking in the right place.
I’ll try again.
Thanks for your input.
Mapping objects moving in 3D real time is no easy task. Anything that does this would have some very fancy algorithms to calculate all the vectors, probably has a custom chip just for that purpose. Would use AI to recognise the ball path and track it. I would not even know where to start considering the maths involved.
Finding a commercial product for a cheap price would be the best option.
H ALL
Good luck with that. But you never know with these clever Chinese these days.
RD-03D Radar is a short-range presence and motion detection sensor, not optimized for measuring fast-moving small objects.I think you need to use Multiple Radar Sensors or a Microphone Array. Doppler Radar Sports Sensors like the Velocity Radar by Pocket Radar, or industrial sensors like InnoSenT IPS-245 or HB100 with custom processing will be best.
