Hi
Could someone advice me the best way to go forward with making a lillypad respond if it’s blown on it to make it light up. If it is even possible.
Cheers Kerry…fashion student
You could use a hot wire anemometer. It relies on the air-flow cooling down the wire and changing its resistance. It’s not something you could easily obtain for your purpose but I did find one here:
You could make one but that would require some electronics knowledge. There’s a short description of how they work here:
This might be interesting. I wondered if the hot-wire could be replaced with a heated diode and it looks like the answer is yes. Somebody used it to create an electronic birthday cake candle that goes out when you blow on it.
https://www.edn.com/design/sensors/4426243/Use-a-heated-diode-as-a-flow-sensor
Thank you
Hi Shaun
Would you b in a position to build it for me as a paying job please?
Sorry Kerry,
I’m flat out on another volunteer project and have a full time job. I’m sure there’s others on he forum that could help you with the information I posted up or maybe have other ideas.
Shaun
Thank you for your ideas so far. Would there be anybody on this forum who could help me please. Cheers Kerry
