Home Assistant Connect ZBT-1 (previously known as Home Assistant SkyConnect) is the easiest way to add Zigbee support to your Home Assistant instance. Home Assistant Connect ZBT-1 can also be used to turn your Home Assistant installation into a Thread border router.
Hi there, @Mark306385, and welcome to the forums. Glad to have you here.
No, the Skyconnect ZBT-1 is not covered under the program. According to Home Assistant:
The replacement program only covers ZBT-1 branded devices purchased prior to October 2024, and not SkyConnect-branded devices (identify which device you have with this graphic).
