It looks like you’ve done everything right. Could you try and post a picture of your wiring so we can take a look at that? The jpeg you referenced didn’t seem to work.
The only concern I have is the 3-pin screw terminals being used with the breadboard - their pins are quite a thick gauge and you might find that pushing them into a breadboard can damage the breadboard or create an intermittent connection fault.
Hi Guys, i removed the 3 pin screw terminal and go the below response. However there is no ID with a 28 - etc and it only responds once. then back to the original. Any Thoughts
I was using a pre-pixel version at the time of that tutorial, but that shouldn’t affect anything. Perhaps the last effort would be to try a fresh image of raspbian? If that doesn’t work, shoot us an email and we can go from there.
Hi Sam. was the first thing i did. Thought i might have broke something. There is a lot of chatter regarding this issue. I have added lines to the config.txt file as some of the raspberry forum’s suggest.
