No worries at all, it’s better to ask and learn something for sure!
There’s definitely an advantage to knowing a few websites for different bits and bobs, if you need a hand with anything else shoot it through!
Your current ribbon length likely isn’t causing tooooo many troubles, I ran a ~500mm cable between my Pi and APA102 LED strips on my printer, and it worked fine as long as I kept it close to the frame (moving it away caused erratic colours). Worth noting too that each APA102 will be cleaning up the signal for the next, so that’s why you’ll see loooong strips, but not necessarily long wires to the strip, in the wild.
I’ve got another thread - now - on that.
Thanks though.
I’m putting together a shopping basket (here) of things to get.
Just there seems to be 3 different flavours of them. So I need to know which size I want.
