New guide: "How to Flash/Write Raspbian OS onto Raspberry Pi Compute Module 4 (CM4)"
While the Raspberry Pi Compute Module 4s (CM4s) share a lot with the regular Pi 4 Model B, the flashing process can be quite different depending on which model you pick! This article aims to demystify that, so without further ado, let’s get cracking!
Nice write-up James
after flashing emmc edit config.txt then tell me next procedure . i want to see separete os in putty
tell me the boot up steps
Disconnect the CM4, remove the BOOT jumper, and power up like any other Pi
