Just want to delete this now
Hi John,
When you say verifying, is that for the Arduino IDE or something else?
In Particle Build, if your verify was successful, you can click the little icon that appears next to Code verified! Great work. to see the memory usage of your code. If it wasn’t successful, you can click the red Show Raw button under the error to display the entire console output. Does that help?
If you put up your code inside a preformatted text block, I can have a look at it for you and help you get back on track with your project.
