Sketch uses 4152 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 252 bytes (12%) of dynamic memory, leaving 1796 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0b
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0b
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hi Andrea, are you talking about connecting an external character or graphical display up to the Arduino to display information? I highly recommend that you take a look through our tutorials section as we’ve created a wide range of Arduino tutorials (always adding) which walk through everything you looking at and more!
avrdude: ser_open(): can’t open device “\.\COM1”: The system cannot find the file specified.
As was the case in your previous circuit, often and overlooked LED or misplaced wire can cause a project to behave unexpectedly. I’d suggest going through and triple checking all of your connections, along with some of our Arduino tutorials I linked you to before.
It’s very hard to assist you - consider your last photo of the circuit. The angle of the photo does have the project in it, but we can’t make out the wiring of your circuit clearly - we can’t see what pins of the Arduino are connected where on the breadboard. Please consider this from our perspective - could you accurately and with confidence determine the circuit given the image you have provided? Perhaps not.
Despite your best efforts, I still can’t see what pins the LEDs are connected to, nor can I see how you have those other devices wired up specifically.
