Incremental 180 degree rotation
Hello Core Forum,
I’m new to electronics and am trying to build my knowledge of component selection for specific goals.
I have a small motor function that requires an incremental 180 degrees of rotational movement. Into Position A for X seconds then a movement into Position B for Y seconds - this will then cycle through (or back and forth) for as long as needed.
Am I correct in assuming I need a Servo and an Arduino board (or something similar)?
Thank you in advance for any input.
Hey Alex,
You’re on the money, a servo sounds like the best option for that! I’d take a look at this tutorial if you’re looking to use an Arduino to control it.
Hope this helps!
Hey Owen,
Thanks for the response! - it’s good to have confirmation on a direction.
