IP68 Waterproof 5-pin Aviation Connector/Cable Plug SPI1310/P (SS320991108)
This is a placeholder topic for “IP68 Waterproof 5-pin Aviation Connector/Cable Plug SPI1310/P” comments.
IP68 Waterproof 5-pin Aviation Connector/Cable Plug SPI1310/P…
For the following product;
Is there a mating chassis mounting socket.
John Bennett
Hi John
Yes. Both mounted with nut in circular hole.
Weipu SP1312/S5 C with cap, N without cap
Weipu SP1315/S5 C with cap, N without cap
Both basically the same except one front mount and the other rear mount.
Panel hole 13mm.
Not sure I understand.
Currently I have a cable entry into a cabinet. What I need though is to fit a waterproof plug onto the cable end and have a matching socket cable entry into the cabinet.
You have given me two part numbers, both appear to be plugs. Is this correct?
John
Hi John
Read the reply again.
They are both socket (female), “S” for socket (/"S"5).
If you need it the other way around you can look up the Weipu web site on the series SP13 page and you will find the sex and part numbers for both configurations.
Can’t make it any simpler than that.
