Hello,
I’m wanting to use a jetson nano in a IP67 sealed water proof enclosure that will be in outdoors
- does the jetson nano require active cooling?
- what solar and battery setup would you recommend?
Hello,
Hi Sam,
The Jetson Nano comes with a heatsink and doesn’t usually require active cooling, but if it’s in a sealed enclosure it might well need it. You will need to provide a heat conduction path out of the enclosure somehow.
As for solar powering, it depends how much you’re running from it - and how often it’s running. If you need it to run 24/7 you’re going to need some decent batteries, solar panels, and charging electronics. If you’re just powering it intermittently you can get away with a lot less - what’s your duty cycle like?
But FYI, I’d suggest taking a look at this:
