Hi there.
I have just this week purchased 2 JRK 12v12 boards from your good selves and have run into a snag.
I soldered the three pins I require for my pot feedback on the first board, along with the block terminals, without an issue. When I began on the “FB” pin/terminal on the second board, solder appeared in the “Aux” terminal. It didn’t flow from the outside, but seem to just appear inside the terminal. I have checked the difference in resistance between the fist boards’ “FB” and “Aux” pin and it is very much higher than the board that has solder now showing inside the “Aux” terminal, indicating to me it is in fact connected to the “FB” terminal.
If I understand the way this board works correctly, I should use either the “FB” terminal as feedback from my pot, or the “Aux” terminal (depending on how you want it set up). If they are somewhat connected this will be an issue, for me.
I am a hobbyist solderer, so not an aficionado, however I feel I don’t do a bad job. I have attached phone pics showing the issue, and a pic of the good board, showing my soldering results. (apologies but the pics looked much clearer on my phone)
What do you recommend I do, or do you think it could be a faulty board? Is it possible for solder to track internally from one terminal to the adjacent terminal?
Any help or suggestions would be appreciated.
