KKSB Case for Raspberry Pi 5 – Compatible with Raspberry Pi DigiAMP+ HAT (KKSB-0003)
This is a placeholder topic for “KKSB Case for Raspberry Pi 5 – Compatible with Raspberry Pi DigiAMP+ HAT” comments.
This Raspberry Pi 5 Case from KKSB Cases has been designed to complement the audio capabilities of the Raspberry Pi 5 setup. The case is compatible with…
Hi guys, Hopi g you can help supply some hardware for this drumpi.com build from your stock. Can you please advise which items you can offer. In particular, which kksb case. Thanks, Aaron
Raspberry Pi 8GB :
https://www.raspberrypi.com/products/raspberry-pi-5/?variant=raspberry-pi-5-8gb
Audio Card :
https://www.raspberrypi.com/products/dac-pro/
Micro SD Card 128GB :
Cooler :
https://www.raspberrypi.com/products/active-cooler/
Power Supply :
https://www.raspberrypi.com/products/27w-power-supply/
Enclosure :
Hey there, @Aaron305984, and welcome to the forums, glad to have you here.
We do supply all of those products and all are currently in stock, please see the links below:
