The case for Raspberry Pi 5 and the Official Raspberry Pi 7" Touchscreen Display has a black aluminium frame and steel base, with access to the majority…
In terms of power banks, We currently don’t stock one that has the required 5V 5A output needed for the Pi 5. The closest we have is this 3.6A one but it will trigger the lower power mode on the Pi 5.
The Pi 5 paired with an NVMe HAT unfortunately won’t fit inside this enclosure. That said, we do have some great alternatives, such as the HighPi Pro Case, which is designed with expansion in mind.
You can also explore more options in our Enclosures category if you’re considering a DIY or custom-fit solution.
When I purchase the KKSB Case for Raspberry Pi 5 and the Official Raspberry Pi 7" Touchscreen it says it comes with the display cable, does it also come with the other motherboard that is shown to be connected to the Pi or does this need to be purchased separately?
