I have a question regarding controlling my LCD1602 with my Raspberry Pi 5. To do this I am using the smbus2 library. Here is my code that uses the smbus library to control the i2c system:
try:
import smbus2
LCD = smbus2.SMBus(1)
address = 0x27
IR = 0
DR = 1
ASCII_WORD = "HELLO"
LCD.write_byte_data(address, IR, 0x80, force=None) #set the cursor at the beginning of line 1
for char in ASCII_WORD:
LCD.write_byte_data(address, IR, 0x10, force=None) #set the cursor 1 column left
for bit in range(8):
LCD.write_byte_data(address, DR, ord(char) >> (7 - bit), force=None)#write ASCII character
except KeyboardInterrupt:
LCD.write_byte_data(address, IR, 0x01, force=None)#clear display
LCD.close()
Here is a great link in which I received most of the data bit values from: LCD 16x2 Pinout, Commands, and Displaying Custom Character
This is what is going on in my code:
- Set the cursor position.
- Write the ASCII of the character I want.
Issue:
The result from this code was unexpected, the cursor position was on the 5th column of the second row and there was a ≣ sign on the first row second column. I soon realised that the for bit in range(8): was unnecessary because the smbus2 library handles converting the decimal values to binary and sending that bit by bit (Please correct me if I’m wrong). This extra loop is likely causing duplicates of ASCII codes.
Debugged code:
try:
import time
import smbus2
address = 0x27
IR = 0
DR = 1
LCD.close()
New Issue:
This code creates an issue where the whole LCD backlight turns off. It could be that the whole LCD turns off, but the power LED stays on.
Debugging:
I tried removing the except block as I thought maybe it was just clearing the display - the backlight was still turning off when I ran the code. I also tried isolating each LCD.write_byte_data() to see if one singular one was causing the issue - each isolated one was causing the backlight to turn off. I then found the “>> (7-bit)” line was still in my code so I removed it. Here is my revised code:
try:
import time
import smbus2
address = 0x27
IR = 0
DR = 1
LCD.write_byte_data(address, DR, ord(char), force=None)#write ASCII character
LCD.close()
There is a new problem that has come up, when I run the above code, the LCD screen stays the same as it is at startup, a blue background. Next, to see if the issue was happening with my old original code where I had an extra for loop that I removed, and when I ran that code the screen turned right off instead of displaying the cursor sign and ≣ signal. So for some reason the outcome of the first code has changed without me modifying it at all.
Could anyone please help me to debug these issues, specifically why the LCD is turning off/not changing at all? I would really appreciate some help. Thank you in advance.
