Purchased a LiFePO4 12.8V 8AH battery to use on the go kart as it is light weight.
Fully charged using a LiFePO4 charger, but is not able to crank the starter motor of a go kart.
Smaller 12V 7AH lead battery from century has no problem starting the kart. Can someone please advise if this is common across all Lithium batteries ?
“Lithium” batteries actually encompass quite a few chemistries and compositions. For instance, a LiPo pack designed for low internal resistance is rated for 75C continuously, where C is the capacity in Amp-hours:
So that tiny little 4Ah pack can output 300A! (though I wouldn’t be game to try it)
To get into perspective a small 1.6L car would probably have a battery with a CCA (Cold Cranking Amps) of some 450 and probably require 200 or so amps to start. My car (2L diesel) requires a battery of 750CCA or at minimum 650 Although I think it is only about 80AHr it is still quite a large battery. What I am getting at is the important number here is the CCA, irrespective of AHr.That is the number of Amps that can be delivered for a short period.
As James says, Horses for Courses.
