This is a placeholder topic for “Lipo Charger-Type C” comments.
This is a Type-C Lipo charger designed for single-cell 3.7V lithium battery. The compact size makes it easy to integrate into your applications. The charger adopts … read more
Is it possible to use this charger with this battery (SKU: CE04377) at the same time as a load is being used? If so, do you have any contextual details of how this might be possible?
Cheers.
Boz
Yes you’d just connect it in parallel with the load and battery.
Hey Aaron,
@Oliver33 is right that’ll work. I’d just check that you’re running at 500mA with the 1000mAh+ batteries or your charging will take a significantly long time.
