Solar Lipo Charger (3.7V) (DFR0264)
This is a placeholder topic for “Solar Lipo Charger (3.7V)” comments.
This Solar lipo charger is designed for single Lithium battery (3.7V) for intelligent charging, with input reverse polarity protection. The maximum charging current is 500 milliamperes and the connection is simple and convenient. Used with the solar battery and lithium battery, you can quickly build a solar power system. Nowadays green power, for stationary or mobile projects is becoming highly requested.
A post was split to a new topic: LiPo Charging
I note in two places the product description refers to “solar battery”. I assume these should read “solar panel” ?
I am looking to charge a 3.6V NiMH battery pack from solar, but a search on core’s shop didn’t return anything … so wondering if this could be used instead ?
Hi Donald,
Well spotted, I’ll have that queued to be updated.
As for charging your NiMH battery I have seen a range of answers about but to my understanding you shouldn’t. These batteries charge differently and this solar charger is designed. This charger provides a constant current and voltage to the battery until it reaches its max voltage, it then trickles its current until the battery is fully charged. Lithium batteries like this type of charging.
NiMH batteries are slightly different. They use a constant current to charge but vary the voltage. This is why you shouldn’t use a Lithium charger here. I can’t see a solar charger that we stock that will work for your batteries unfortunately
I noticed that your specs for this LiPo Charger doesn’t specify the VOUT voltage.
DFRobot’s wiki includes:
  • BAT: Connect a 3.7V lithium battery, for storing electricity.
  • VOUT: Lithium-ion battery output. Connect your electrical equipment to it.
Note that most other Solar Power Managers provide regulated 5V, so this is a significant difference.
I’m comparing this DFRobot Solar LiPo Charger vs the DFRobot Solar Power Manager 5V, and these seem the most significant differences:
Solar LiPo Charger Solar Power Manager 5V
Output VOUT is the LiPo battery output Regulated 5V 1A output
charge from Solar panel only Solar Panel, USB or other 5V source
protections Short Circuit/Over Current
Max Charging Current 500mA 900mA (Solar/USB)
Share and Enjoy…
Hey there, @Donald23173,
Yep, a significant difference. The DFR0264’s VOUT is directly tied to the LiPo rather than a regulated output.
From the DFRobot Wiki’s page:
So it looks like this unit is designed to be disconnected from the Solar Panel when powering a project. Which would explain why it is called a ‘Solar LiPo Charger’ instead of an ‘SPM’.
