I want to couple 2 load cells about 8m apart.I want to set up one load cell to which I can apply, and vary, a load. I want to set up a 12v/10a motor and mechanical linkage to apply or reduce the load (run in forward and reverse) on the second load cell to achieve balance using the wheatstone bridge principle.
I have 4 50kg load cells, load cell amp, load combinator, Redboard, relays etc. The arduino requirement has lost me. Can anyone help with a simplistic solution?
Bruce Atkinson
Load cell balance with 12v motor and wheatstone bridge
Hi Bruce!
I’m not entirely clear on what you are trying to accomplish, could you please draw up a simple sketch to help me get my head around it?
Hello Stephen
Thanks for contacting me.
I have wired up the load cells, amplifier, combinator redboard. The two ‘spare’ load cells have screw loading arrangements as ‘trimmers’. I am unable to decifer what to do with my computer and redboard. Is there a relatively simple way I can get an output (
resistive?)to drive the motor. I have set up the system with ‘pots’ and it works ok, but my load sensing does not have sufficient movement , so I need to use load cells. I have not connected my computer to the redboard. I saw a suggestion I could wreck the board with the wrong o.s. ( I have windows 10).
Any advice on what to do or where to go is much appreciated.
Wiring schematic attached.
Cheers Bruce
Hi Bruce,
There is no danger of messing up your Redboard from connecting it to a computer. You will need to connect it to a computer to program it.
I recommend you check out our Arduino Workshop for Beginners, it has all the basics you need to get started using your Redboard for projects:
You can find some information on controlling a motor with Arduino(redboard) here:
Hello again Stephen
I have failed to get a sensible resolution to my problem. I have been able to install a code into the redboard, but not one that does what I need. Writing my own code is beyond me. Can you please provide me with an appropriate code for the system, ie 4 load cells wired as wheatstone bridge thru combinator then to amplifier and to redboard. I want to be able to detect a variation in one load cell due to an applied force, then apply a force to a second load cell that achieves balance electrically via the wheatstone bridge principal. I need a code for the redboard that provides me with a workable dc (5v?) output on pins to operate the mechanical loading operation to achieve the electrical balance.
Bruce Atkinson
Hi Bruce,
Unfortunately I can’t write the code for you. If you break your problem down into parts I’m happy to help with any specific questions or take a look at any code that you’ve written and give feedback!
