I am using the Trinket M0 for the first time. A simple Blink pgm compiles but it never gets fully loaded. I am not sure how to attach a file with the images of the error.
I get the message avrdude: ser_recv(): Programmer is not responding
Can you please send through your script and a picture of your setup so that we can take a look for syntax errors or anything else that we may be able to find that’d help with troubleshooting on this board. Also is there anything else that you’ve tried that we may be able to analyse. All the best!
Gents, I have been researching the issue on the Adafruit website and they talk about USB incompatibility with Trinket … I am using a 9-10 year old laptop for this project (lighting buildings with neopixels on my model RR) … The laptop does have Windows 10.
I am going to rebuild and test with a current technology desktop and see if that is where the problem is … I will get back to you in a few days … thanks
Frustrating isn’t it. But don’t kick the cat too much.
Why not see if we can’t get the laptop working as well?
My thought is that Windows on the laptop has decided to use the wrong device driver for the board, and even if you install the correct for the Trinket M0, Windows is quite happy to continue using the wrong driver. It may be necessary to manually change the driver for the board.
Does Windows device manager show the same device driver on both machines?
