I am a student doing my HSC and saw a YouTube video showing a 10x10 matrix which uses an Arduino board and RGB LED strip (WS2812B). My project is to help students with numbers and algebra.
I need the strip to count from 1-100. I have found a simple code in Arduino example from downloading Fast LED library and picked FirstLight. I manipulated the code by simply changing the values. I had the strip counting up by 1s, 2s, 3s, 4s, 5s and so on. I need buttons so that the students can press it and be able to count up numbers by whichever number they want but I don’t know how I’m going to code it or connect all of them together. I’m not very good at coding, would you be able to give me a hand?
We don’t want to take all of the fun out of your HSC project! Though if you find that it becomes too hard to remix someone else’s code to do something a different, then it might be worth building something from the ground up.
https://core-electronics.com.au/tutorials/ws2812-addressable-leds-arduino-quickstart-guide.html
The above guide will walk you through how to use WS2818 LEDs from a low-enough level that it could be remixed for anything. Using an array for a 10x10 image, along with a couple of constants which hold the patterns for each number, you could whip this up with a couple of functions.
Here’s something we did with a Raspberry Pi a little while ago, perhaps you’ll find some inspiration to make use of bigger pixel-patterns as we did.
https://core-electronics.com.au/projects/led-pixel-matrix
Is there any chance that I could come by and show you my project?
This is code I have used to detect a button press using interrupts.
// declare variable to hold state of button press
bool ButtonON = false;
// interrupt routine for button press
void ButtonPressedISR() {
ButtonON = true;
void setup() {
// push button on Digital pin 2
pinMode(2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), ButtonPressedISR, FALLING);
void loop() {
if (ButtonON) {
// set variable to change the way the display counts
// this could increment, so pressing the button would step through the available options
// reseting when it got to the top level
ButtonOn = false;
