Hi All,
I am trying to connect the “Makerverse LoRa-E5” to a Raspberry Pi 4 and have made the necessary connections to the Pi. Could someone help me tweak this program to make it work with the Raspberry Pi 4?
# Connect to The Things Network (TTN) and publish some test data
# How to get started:
# • Create an account on cloud.thethings.network
# • Create an application
# • Run this script to get the JoinEUI and DeviceEUI
# • On your applicaiton, generate an AppKey and paste it as a string in the code below.
# • Run this script again
# • Monitor your applicaiton console and look for a test message being received on TTN
# This demo is based off the Getting Started Guide by seeedstudio:
# https://wiki.seeedstudio.com/LoRa-E5_STM32WLE5JC_Module/#getting-started
# Refer to the AT Command Specification
# https://core-electronics.com.au/attachments/uploads/lora-e5-at-command-specification-v1.0.pdf
# Put your key here (string). This should match the AppKey generated by your application.
#For example: app_key = 'E08B834FB0866939FC94CDCC15D0A0BE'
app_key = 'None'
# Regional LoRaWAN settings. You may need to modify these depending on your region.
# If you are using AU915: Australia
band='AU915'
channels='8-15'
DR='0'
# If you are using US915
# band='US915'
# channels='8-15'
# DR='1'
# If you are using EU868
# band='EU868'
# channels='0-2'
# DR='0'
from machine import UART, Pin
from utime import sleep_ms
from sys import exit
uart1 = UART(1, baudrate=9600, tx=Pin(4), rx=Pin(5))
join_EUI = None # These are populated by this script
device_EUI = None
### Function Definitions
def receive_uart():
'''Polls the uart until all data is dequeued'''
rxData=bytes()
while uart1.any()>0:
rxData += uart1.read(1)
sleep_ms(2)
return rxData.decode('utf-8')
def send_AT(command):
'''Wraps the "command" string with AT+ and \r\n'''
buffer = 'AT' + command + '\r\n'
uart1.write(buffer)
sleep_ms(300)
def test_uart_connection():
'''Checks for good UART connection by querying the LoRa-E5 module with a test command'''
send_AT('') # empty at command will query status
data = receive_uart()
if data == '+AT: OK\r\n' : print('LoRa radio is ready\n')
else:
print('No LoRa-E5 detected\n')
exit()
def get_eui_from_radio():
'''Reads both the DeviceEUI and JoinEUI from the device'''
send_AT('+ID=DevEui')
device_EUI = data.split()[2]
send_AT('+ID=AppEui')
join_EUI = data.split()[2]
print(f'JoinEUI: {join_EUI}\n DevEUI: {device_EUI}')
def set_app_key(app_key):
if app_key is None or app_key == 'None':
print('\nGenerate an AppKey on cloud.thethings.network and enter it at the top of this script to proceed')
exit()
send_AT('+KEY=APPKEY,"' + app_key + '"')
receive_uart()
print(f' AppKey: {app_key}\n')
def configure_regional_settings(band=None, DR='0', channels=None):
''' Configure band and channel settings'''
send_AT('+DR=' + band)
send_AT('+DR=' + DR)
send_AT('+CH=NUM,' + channels)
send_AT('+MODE=LWOTAA')
receive_uart() # flush
send_AT('+DR')
print(data)
def join_the_things_network():
'''Connect to The Things Network. Exit on failure'''
send_AT('+JOIN')
print(data)
status = 'not connected'
while status == 'not connected':
if len(data) > 0: print(data)
if 'joined' in data.split():
status = 'connected'
if 'failed' in data.split():
print('Join Failed')
exit()
sleep_ms(1000)
def send_message(message):
'''Send a string message. The user's message string is wrapped in double quotes by this funciton'''
send_AT('+MSG="' + message + '"')
done = False
while not done:
if 'Done' in data or 'ERROR' in data:
done = True
sleep_ms(1000)
def send_hex(message):
'''Send a data message in hex format. The user's message string is wrapped in double quotes by this funciton'''
send_AT('+MSGHEX="' + message + '"')
done = False
while not done:
done = True
sleep_ms(1000)
# The main program starts here
configure_regional_settings(band=band, DR=DR, channels=channels)
# Send example data
print("sending test messages")
send_message("Hello, World!")
send_hex("00 11 22 33 44 55 66 77 88 99 AA BB CC DD EE FF")```
