Can I use the MAX3421E-based USB Host Shield to interface the Microsoft Sidewinder Precision 2 joystick to an Arduino R4? I am just needing to map the J/S codes without having to mechanically convert the optical sensors’ outputs.
The SideWinder probably won’t map directly through the keyboard/mouse examples, but provided you do a little bit of experimentation, you should be able to get everything off the ground.
Start with the most up to date USB Host Shield Library 2.0 and use the USBHID_desc example to confirm enumeration and print the joystick’s HID report descriptor.
Once you have that, you can move on to HIDUniversal plus a small report parser to extract the communication representing its axes, hat and button bits from each input report, and start integrating them to do what you like on the Arduino.
