Hi team,
How long would be the maximum length of a cable for connecting PiicoDev modules together? e.g.
4 Wire Telephone Cable, or CAT5e cable.
Thanks,
Hi team,
Thanks,
Hi Farhad,
The PiicoDev modules use the I2C protocol to communicate so their limitations are based on that. As the name, Inter-integrated-circuit implies it’s made for very short distances.
Some sources say around 1 meter is the longest you can get.
Ultimately it is a result of the capacitance between your cables and the pull up resistance of your data lines.
There is some discussion on stack exchange here: Maximum I2C Bus Length? - Electrical Engineering Stack Exchange
And a look into the mathematics behind the limitations here:
I2C Cabling | Analog Devices
Thank you!
Can I use Adafruit LTC4311 I2C Extender at the end ( or beginning) of a chain of Piicodev modules.
Hi Farhad,
Yeah, it looks like this one would be best placed at the start of the chain. JP from Adafruit has a great video on it here: JP’s Product Pick of the Week 12/1/20 LTC4311 I2C Terminator @adafruit @johnedgarpark - YouTube
If you are keen on doing some conversion you can use a voltage to current converter to send the signal down a massive cable.
Liam.
