Hi guys,
I am building a robot with PiicoDev devices but wanted to use another non-PiicoDev I2C device with the other 3 devices on the robot, which include:
the VL53L1X distance sensor
the PiicoDev SSD1306 OLED Display
the PiicoDev LIS3DH
I want to add a TOF10120 that I have lying around as the rear distance sensor and was wondering how to go about it so that there are no clashes with addresses, etc. Can you let me know if there are any raspi pico python libraries that I could use and what to do about the addresses?
VL531X - 0x53 - Can be changed in software each on startup
OLED - 0x3C - Can be changed to 0x3D with Adress SWitch
LIS3DH - 0x19 - Can be changed to 0x18 with Adress SWitch
I googled the TOF10120, looks like someone has written Python code for a full-size Pi, shouldn’t be too hard to do some more searching or port it to microPython:
Looking at the code it looks like the sensor sits on 0x52, so as long as you don’t add an ENS160 or RV3028 you should be fine
P.S. in future, you can just dig into the Core Electronics Github to find address info, for example here’s the SSD1306 code:
