What is the length of this power supply and what is the maximum cable length available?
Hi Max,
It’s about a meter, though you could extend it pretty easy if you are comfortable with that sort of thing.
Max,
I asked this question sometime ago…
The advice that @Graham gave me was to make sure that I could provide plenty of power to combat losses / voltage drop in the (longer) cable.
Turns out that it was good advice. I am using the Raspberry Pi power supply to power a Pi Zero W thats located about 5 - 6m away from the wall socket. I used a twisted pair CAT5 cable as my ‘extension’ and used 2 twisted cores for the +ve and two twisted cores for the -ve.
No problems with it after the best part of 2 years.
Jon
Great hack Jon, thanks for sharing!
