Objective is the use the mBot to trace a chalk pattern on a sidewalk, driveway or parking lot.
The mBot would be programmed to follow any black and white clip-art pattern. The pattern would be converted into a vector path using the free Inkscape software. This path profile would be converted into a G-Code text file using the G-Code generator in Inkscape. (FYI there are other programs that do this as well)
I have the mechanics and hardware worked out along with free software options to generate the G-Code clip-art pattern text file the robot would follow. Have been exploring the mBot, but I need coding help. I don’t know how or if the mBot can be set up to read a G-Code text file of X Y coordinates that create the pattern.
Hi Dave,
Welcome to the forum
This looks like an awesome project!
We stock two versions of the mBot, both with Bluetooth pairing. The mBot can be programmed using a version of Scratch 2.0 called mBlock which is a graphical programming language, or with C++ via the Arduino IDE.
I’m not sure whether you would be able to establish communications with the mBot effectively and feed it live instructions, but compiling the G-code or X Y coordinates into a program that can be executed, then re-programming the bot for the next image to draw via Bluetooth should be do-able.
mBot user manual
Hi Trent and thanks for the reply. I’m glad to here that there is some possibility. I believe it would be fun for kids to learn some CAD design along with robotics. Also, gCode files could be pre created for download. Would like to turn this into a sell-able add-on for mBot.
Thoughts…
