Hi James
If everybody did this and left enough head room it would solve a lot of problems.
Worth remembering. EVERYTHING starts at the power source. If this is not up to the task any project is doomed to failure.
Good thinking. This is a proven product and I don’t think will cause much trouble.
As promised have had a look with an oscilloscope and have 3 interesting pics for you and anyone else interested.
Pic 1. Output with 12.3A (highest I can test) load
As you mentioned this hardly makes spec but the next pic is interesting.
Pic 2. As above with the oscilloscope chassis (case) ground removed.
Having the ground in place effectively connects output negative to mains earth via the long route probe earth, mains lead to power supply then supply case. Quite a long ground path. I have a short mains extension with the earth wire disconnected for this express purpose. The wire is left hanging out of the connectors so it is obviously disconnected.
The supply negative is normally isolated from frame ground (confirmed by measurement) and is connect via a capacitor.
My measurements taken with oscilloscope ground clip connected to supply neg.
As you can see the "noise and ripple are now well below the 100mV spec.
The periodic spikes that you mention are still evident but the period has changed. But just about make it at 100mV.
Pic 3 is the result with the power supply off and unplugged. Output loaded for a few secs to discharge any output caps.
Interestingly there is still evidence of these spikes. This makes me believe that they may not be really there and are being introduced by measurement stray pick up from somewhere. The period seems to have change again.
I suppose anything could happen.
I hope this clears up the last of your doubts
I think this points out how easy it is to introduce spikes, ringing etc which is not really there. This sort of thing came up recently with long scope earth leads measuring I2C pulses.
removing the scope frame ground is a throwback to analog TV where having this ground connected to mains earth introduced all kinds of problems which were not really there. My oscilloscope frame is usually ungrounded but this is a new one and I just plugged it in.
I expect the absolute safety brigade will throw their hands in the air about this. Probably rightly so. You just have to get used to being careful. If you do things like looking at the voltage across a motor or similar you will probably have some sort of a disaster if you don’t remove the frame ground. Indeed in the past on TV instruments Tektronix provided this facility easily. You simple turned the 3 pin mains connector over and the ground disappeared.
Stupid me, can’t even read my own oscilloscope scale. Although I have an excuse, I have only had this one for a couple of days.
Big change: The horizontal scale is 5µSec/division. I was looking at the sample rate and reading 50mSec/div which was still wrong.
Puts a different light on things what???
