Hi there
We are looking to control a flap in and pipe to bypass air with a Pololu simple motor controller. With an Arduino required to run it. (maybe the Astar 32u4??)
We need some code to use the I2C interface that will allow the following to work:
1:When we receive an input signal the flap needs to open (Run the motor forward.)
2:Then after losing the input signal the flap needs to close (Reverse the motor.)
3:We do have the availability to have an additional input to override the flap closing(2:)
The motor has no limit switch. So timing it would help, 1-3 seconds should be enough.
and a delay in closing from full open would be usfull also so it dosent close during shifting whilst under the boot
The input signal to open the flap is a PWM frequency@ 3.3v (which we can modify)
any help in the right direction would be greatly appreciated
Matt
