Hey Michael,
Yeah, something stops the rest of the loop running when I try to add the octave change code.
This is what I’m running;
struct key
int pin;
int midiKey;
int debounce;
int keySent;
struct key keys[] =
{ 22, 25, 0, 0 }, // Db red
{ 24, 26, 0, 0 }, // D red
{ 26, 27, 0, 0 }, // Eb orange
{ 28, 28, 0, 0 }, // E orange
{ 30, 29, 0, 0 }, // F yellow
{ 32, 30, 0, 0 }, // Gb green
{ 34, 31, 0, 0 }, // G green
{ 36, 32, 0, 0 }, // Ab blue
{ 38, 33, 0, 0 }, // A blue
{ 40, 34, 0, 0 }, // Bb violet
{ 42, 35, 0, 0 }, // B violet
{ 44, 36, 0, 0 }, // C brown
{ 48, 24, 0, 0 }, // C brown
{ 0, 0, 0, 0 } // end of list marker
int keyOffset = 12;
int sensorPin = A0;
int sensorValue = 0;
int keyVelocity = 100;
void setup() {
// put your setup code here, to run once:
for(int i = 0; keys[i].pin != 0; ++i)
pinMode(keys[i].pin, INPUT_PULLUP);
//start serial with midi baudrate 31250
Serial.begin(31250);
void Midi_Send(byte cmd, byte data1, byte data2)
Serial.write(cmd);
Serial.write(data1);
Serial.write(data2);
void noteOn(int midiKey)
Midi_Send(0x90, midiKey, keyVelocity);
void noteOff(int midiKey)
Midi_Send(0x80, midiKey, keyVelocity);
void loop() {
// put your main code here, to run repeatedly:;
keyVelocity = (int(map(analogRead(sensorPin),0,1023,0,127)));
sensorValue = analogRead(sensorPin);
byte byte1;
byte byte2;
byte byte3;
int value;
//*************** MIDI THRU ******************//
if(Serial.available() > 0)
byte1 = Serial.read();
byte2 = Serial.read();
byte3 = Serial.read();
Midi_Send(byte1, byte2, byte3);
// Look for bass pedal key events
value = digitalRead(keys[i].pin);
if(keys[i].debounce == 0) // Key has been off
if(value == LOW) // Key is now on
noteOn(keys[i].midiKey + keyOffset); // Send the MIDI note on message
keys[i].keySent = keys[i].midiKey + keyOffset;
keys[i].debounce = DEBOUNCE; // Set the note off debounce counter
else // Key has been on
if(value == HIGH) // Key has gone off
if(–keys[i].debounce == 0) // If Key has remained off for DEBOUNCE scans,
noteOff(keys[i].keySent); // In case the offset has changed, send MIDI off for the right note
else // Key has not gone off
keys[i].debounce = DEBOUNCE; // Reset debounce counter in case we got
// a small number of key off scans
