Hi all,
I purchased a GY-GPS6MV2 recently and have had difficulty powering the module.
My first observation was that the onboard regulator was getting quite hot when applying power. This was the case when trying a range of supplies (3.3v @ 50mA/1A, 5v@700mA/1A). Using a DMM inline to measure the current, it appeared that the circuit was trying to draw as much current as possible from the supplies. The supply voltage is being seen at the Vcc/GND pins, however at the regulator input there is a voltage drop occurring.
Next, I tested the circuit for continuity. There is connectivity between the regulator output and GND, and therefore; across the output capacitor and GPS Vcc/GND pins also. Something might be shorting.
Is it possible that the device may be faulty?
