This GPS module is well known amongst the community and is often used with the ArduCopter gear. At the core is a U-blox Neo-6 GPS receiver which has advanced power management and anti-jamming technology. The module takes care of all the hardware requirements leaving only 4 connections to your micro/external application (Vcc RX TX Gnd).
I’m about to integrate this into COTS module one of my designs, and was looking for some mechanical dimensions, namely:
envelope dimensions
mounting hole sizes and placement
I can see that the ublox module itself is 2.2-2.6mm tall, is it possible to post a marked-up 2D projection of the PCB/PWB with GY-GPS6MV2 on its silkscreen?
I made a 3D model in Tinkercad of this module. Did not have dimensions off a datasheet so took the measurements myself. I’ve used this to design a board and case to house the GPS module and other components. Very helpful.
Below is the .stl file of the model. You can import this into Tinkercad and other 3D viewing and cad programs.
The max voltage that can be applied to this board is 3.3V any higher voltage could potentially permanently damage your board. If you have a higher voltage power supply I’d recommend using a regulator or a logic level converter such as those that I’ve linked below.
No Vin is different to Vcc. Vin can accept higher voltage levels for power, but the logic level pins and voltage the reaches the actual GPS chip (including Vcc) can only be exposed to 3.3v.
It’s worth noting that despite ‘timepulse’ being listed under ‘features’, this is not broken out, so you’d have to solder a bodge wire to pin 3 to access the 1Hz timepulse signal
