This is a placeholder topic for
“NeoPixel Mini 3535 RGB LEDs w/ Integrated Driver Chip - Black - Pack of 100” comments.
Itsy Bitsy Teenie Weenie Mini NeoPixel RGB LEDinis! Make your own smart LED arrangement with the same integrated LED that is used in our NeoPixel strips and pixels. We use this same LED in our Metro M4 Express and Neo TrinKey.
Is the NeoPixel Mini 3535 RGB LEDs w/ Integrated Driver Chip - Black - Pack of 100 the same as SK6812-mini 3535?
Hi Frank,
Welcome to the forum!!
For most applications, you’ll be able to use them interchangeably (the 24bit protocol is the same).
Pololu mentions:
The main difference between the two drivers is that the SK6812 has voltage-independent color and brightness over a wide voltage range, which means that the colors of the LEDs should not be affected by a drop in the supply voltage as much as they are on the WS2812B.
