Pi Pico controlling Adafruit A4988 stepper driver and 24byj 48
Hi All ,
I have been working through a number of stepper control designs over the past few months.
Presently I have a Pico controlling an Adafruit A4988 with a 24BYJ48 and an ssd1306 to give information feedback.
This is so I can mount a GoPro on it to perform rotational Time Lapse movies
It is all working really well except that at approx line 185/186 in the code below I have included the line
move_stepper_steps(STEPS_PER_MOVE)
Here is an explanation of the problem taken from the comments in the code
 # <<<<<  if this line is included the ssd1306 and REPL counts down the steps and the motor doesn't move,
 ##  if it is commented out then the motor will move but there will not be a count in either place
Here is the full code
# from 12v stepper Pico Works well now attempting to
#  add print and ssd1306 information
# import machine
# import time
from machine import Pin, SoftI2C
import time
from machine import Pin, I2C
from ssd1306 import SSD1306_I2C
from time import sleep
import ssd1306
oled_width = 128
oled_height = 64
# Example uses I2C(0) with GP4 (SDA) and GP5 (SCL) - commonly used in tutorials
#i2c = I2C(0, sda=Pin(8), scl=Pin(9), freq=400000)
i2c = SoftI2C(scl=Pin(5), sda=Pin(4))
# Initialize the SSD1306 driver (128x64 pixels is common, adjust if using 128x32)
oled = ssd1306.SSD1306_I2C(128, 64, i2c)
# Clear the display buffer
oled.fill(0)
oled.show()
# Display parameters
LINE_HEIGHT = 8  # Standard font height in pixels
MAX_LINES = oled_height // LINE_HEIGHT
# --- Pin Definitions ---
DIR_PIN = 7
STEP_PIN = 8
ENABLE_PIN = 11
BUTTON_START = 9   #RED/BLACK  MOMENTARY
BUTTON_DIR = 14    #SMALL BLACK MOMENTARY
LED_STEP = 18  #RGB  BLUE
LED_END = 17  # RGB  RED
LED_CW = 26   #red / green
LED_CCW = 27  #red / green
# --- Setup ---
direction_pin = machine.Pin(DIR_PIN, machine.Pin.OUT)
step_pin = machine.Pin(STEP_PIN, machine.Pin.OUT)
enable_pin = machine.Pin(ENABLE_PIN, machine.Pin.OUT)
btn_start = machine.Pin(BUTTON_START, machine.Pin.IN, machine.Pin.PULL_UP)
btn_dir = machine.Pin(BUTTON_DIR, machine.Pin.IN, machine.Pin.PULL_UP)
led_step = machine.Pin(LED_STEP, machine.Pin.OUT)
led_end = machine.Pin(LED_END, machine.Pin.OUT)
led_cw = machine.Pin(LED_CW, machine.Pin.OUT)
led_ccw = machine.Pin(LED_CCW, machine.Pin.OUT)
# --- Initial State ---
motor_running = False
direction = 0 # 0 for CW, 1 for CCW
# Power on flash 2x
for _ in range(2):
    led_step.value(1)
    time.sleep(0.25)
    led_step.value(0)
    time.sleep(0.25)
    led_end.value(1)
    time.sleep(0.25)
    led_end.value(0)
    time.sleep(0.25)
    led_cw.value(1)
    time.sleep(0.25)
    led_cw.value(0)
    time.sleep(0.25)
    led_ccw.value(1)
    time.sleep(0.25)
    led_ccw.value(0)
    time.sleep(0.25)
# Initialize states
enable_pin.value(0) # Disable motor (High = Disable)
current_dir = 1 # 1: CW, 0: CCW     0  ###    1: CW, 0: CCW with this setup it starts CW  //  0: CW, 1: CCW with this setup it starts CCW
direction_pin.value(current_dir)
led_cw.value(1)
led_ccw.value(0)
# 1/16 mode needs 16 times more steps for same rotation
# 300 steps at 1/16 is fine, it means roughly 18 full steps (300/16)
STEPS_TO_MOVE = 7000   #8500     ===== close to 180deg
STEP_DELAY = 0.015   # this value is variable depending on the final requirements
STEPS_PER_MOVE = 10   #  this =  7000 total steps  which = approx xxx min,, this value is             #also variable
STEP_COUNT = 0
# Display text: text(string, x, y)
oled.text("Rotating T/L", 0, 0) # Top-left corner
#oled.fill    #()
oled.show()
oled.text("TOTAL STEPS 7000", 0, 18)
oled.text("Mode = 1/16 mode", 0, 28)
oled.show()
time.sleep(2.0)  #5
oled.fill(0)
oled.show()
oled.text("PRESS RED (side)", 0, 18)
oled.text("TO START(button)", 0, 28)
oled.show()
time.sleep(2.0)  #3
oled.fill(0)
oled.show()
print("Total Steps =100")
print("ACTUAL_STEPS count down from...{7000, 1/16 mode}")
def toggle_direction(pin):
    global current_dir
    time.sleep_ms(50) # Debounce
    if btn_dir.value() == 0:
        current_dir = 1 - current_dir
        if current_dir == 0:
            led_cw.value(1)
            led_ccw.value(0)
        else:
            led_cw.value(0)
            led_ccw.value(1)
        print("Direction changed:", "CW" if current_dir == 0 else "CCW")
# Attach interrupt for direction button
btn_dir.irq(trigger=machine.Pin.IRQ_FALLING, handler=toggle_direction)
print("Ready. Push Button (GP2) to start.")
def move_stepper_steps(steps):
    """Moves the stepper motor a specified number of steps."""
    global STEP_COUNT
    remaining_steps = 7000 - STEP_COUNT
    name = "Remain"
#          # 2. Convert variables to strings and draw text
#          # oled.text("text", x_coord, y_coord, [color])
    oled.text("Steps: " + str(remaining_steps), 0, 48) # Convert float to string
    oled.text("count down", 0, 14)
    oled.text("{from 7000}", 0, 28)
    oled.text("Remain:",0 ,38)
    #oled.text("{7000-STEP_COUNT}",0, 38)
    #oled.text("Total steps: {STEP_COUNT % TOTAL_STEPS}", 0, 32)
    oled.show()
    time.sleep(2.0)
    oled.fill(0)
    oled.show()
    #seq = STEP_COUNT
    for _ in range(abs(steps)):
        # Calculate the current step in the sequence
        #seq_index = STEP_COUNT % len(STEP_SEQUENCE)
        Remain = STEPS_TO_MOVE - STEPS_PER_MOVE
        current_step = Remain
        # Update step count with direction consideration
        if STEP_COUNT ==():
            STEP_COUNT += 1
        else:
            STEP_COUNT += 1
        if STEP_COUNT < 0:
            STEP_COUNT = len(STEPS_TO_MOVE) - 1
            #STEP_COUNT = len(STEPS_PER_MOVE) - 1
        print(f"Moved {STEPS_PER_MOVE} steps.  Actual steps: {STEPS_PER_MOVE+STEP_COUNT}. Remain:{7000-STEP_COUNT} ")
while True:
    if btn_start.value() == 0:
        time.sleep_ms(100) # Debounce
        print("Starting sequence...")
        oled.fill(0)
        oled.show()
        oled.text("IN PROGRESS", 0, 18)
        oled.show()
        time.sleep(3.0)
        enable_pin.value(0) # Enable motor
        # Move motor
        for _ in range(STEPS_TO_MOVE):   #  = TOTAL STEPS
            #move_stepper_steps(STEPS_PER_MOVE)    # <<<<<  if this line is included the ssd1306 and REPL counts down the steps and the motor doesn't move,
            #move_stepper_steps(STEPS_TO_MOVE)
            step_pin.value(1)
            led_step.value(1)
            time.sleep(STEP_DELAY)
            step_pin.value(0)
            led_step.value(0)
        # End sequence: Fast blink
        print("Sequence complete. Ending...")
        oled.fill(0)
        oled.show()
        oled.text("Sequence end", 0, 18)
        oled.show()
        time.sleep(3.0)
        oled.fill(0)
        oled.show()
        for _ in range(30):
            led_end.value(1)
            time.sleep_ms(50)
            led_end.value(0)
            time.sleep_ms(50)
        enable_pin.value(1) # Turn off motor
        print("Motor off.")
        oled.text("Motor Off", 0, 28)
        oled.show()
        time.sleep(10.0)
        oled.fill(0)
        oled.show()
        time.sleep(1) # Debounce start button
I am not sure what I need to do to be able to have the motor moving and the count down happening at the same time. Preferably in both places .
Any assistance will be appreciated
cheers
Nick
Hey there, @Nicholas193967,
I can’t find anything specific that would be causing the exact issue, but I do have a lot of weird things in this code., for one:
        if STEP_COUNT ==():
            STEP_COUNT += 1
        else:
            STEP_COUNT += 1
        if STEP_COUNT < 0:
As written, this does not make any sense.
The first if / else checks to see if Step_Count is an empty tuple, which it should never be, because then you’d break your code trying to add 1 to an immutable tuple, but it just goes ahead and adds one anyway if it’s not a tuple?
But then, if it’s less than 0, it then says to minus one from the length of STEPS_TO_MOVE, but steps to move is an integer which means that if it ever was less than 0, your code will crash.
It’s probably best to tidy up your code a little bit to make it easier to follow the chain of logic. I find trimming the fat like that often leads to the solution to the probkem.
Hi Jane ,
Thanks for getting back to me .
I have cleaned that up , thanks for noticing , however the problem is still there,
cheers
Nick
Removed
if STEP_COUNT < 0:
Ok, so, once more I must say that there is a lot going on in this code.
I would really look into reducing if not outright eliminating the global variables in this code. You have formatted them in all caps like they’re constants (STEPS_PER_MOVE), but since you keep changing them they real should be lowercase for variables (steps_per_move). Global Variables are frowned upon in a lot of programming languages. They have their uses, but they are dangerous and can easily lead a programmer astray.
In your code, it becomes extremely difficult to debug because of the number of Global Variables that you are using.
Hi Jane,
I have cleaned up the code significantly (thank you).
It will turn the motor but still will not display the count down on either thonny or the ssd1306.
I have tried moving various blocks of code into different places( different order) but creates new errors
code below
thankyou
Nick
import time
import ssd1306
oled_width = 128
oled_height = 64
oled.fill(0)
oled.show()
DIR_PIN = 7
STEP_PIN = 8
ENABLE_PIN = 11
# --- Setup ---
# Power on flash 2x
for _ in range(2):
    led_step.value(1)
    time.sleep(0.25)
    led_step.value(0)
    time.sleep(0.25)
    led_end.value(1)
    time.sleep(0.25)
    led_end.value(0)
    time.sleep(0.25)
    led_cw.value(1)
    time.sleep(0.25)
    led_cw.value(0)
    time.sleep(0.25)
    led_ccw.value(1)
    time.sleep(0.25)
    led_ccw.value(0)
    time.sleep(0.25)
# Initialize states
led_cw.value(1)
led_ccw.value(0)
steps_to_move = 7000   #8500     ===== close to 180deg
step_delay = 0.015   # this value is variable depending on the final requirements
steps_per_move = 10   #  this =  7000 total steps  which = approx xxx min,, this value is             #also variable
step_count = 0
oled.show()
oled.show()
time.sleep(2.0)  #5
oled.fill(0)
oled.show()
oled.show()
time.sleep(2.0)  #3
oled.fill(0)
oled.show()
print("Total Steps =7000")
            led_cw.value(1)
            led_ccw.value(0)
        else:
            led_cw.value(0)
            led_ccw.value(1)
    remaining_steps = 7000 - step_count
    name = "Remain"
    oled.text("{7000-step_count}",0, 48)
    oled.show()
    time.sleep(2.0)
    oled.fill(0)
    oled.show()
    print(f"Moved {steps_per_move} steps.  Actual steps: {steps_per_move+step_count}. Remain:{7000-step_count} ")
        Remain = steps_to_move - steps_per_move
        name = Remain
        if step_count ==():
            step_count += 1
        else:
            step_count += 1
        #print(f"Moved {steps_per_move} steps.  Actual steps: {steps_per_move+step_count}. Remain:{7000-step_count} ")
while True:
        oled.fill(0)
        oled.show()
        oled.show()
        time.sleep(3.0)
        #move_stepper_steps(steps_per_move)
        # Move motor
        for _ in range(steps_to_move):   #  = TOTAL STEPS
            #move_stepper_steps(steps_per_move)    # <<<<<  if this line is included the ssd1306 and REPL counts down the steps and the motor doesn't move,
            step_pin.value(1)
            led_step.value(1)
            time.sleep(step_delay)
            step_pin.value(0)
            led_step.value(0)
        oled.fill(0)
        oled.show()
        oled.show()
        time.sleep(3.0)
        oled.fill(0)
        oled.show()
        for _ in range(30):
            led_end.value(1)
            time.sleep_ms(50)
            led_end.value(0)
            time.sleep_ms(50)
        print("Motor off.")
        oled.show()
        time.sleep(10.0)
        oled.fill(0)
        oled.show()
