Hi, it’s been a while. I’m going to finally assemble my Pimoroni Picade 10” screen which originally uses Pi 3. Now I’ve read that it is possible to upgrade to a Pi 4.
Can some kind soul point me to the advantages, how to upgrade, and what is required (apart from the obvious Pi 4).
This tutorial should be all you need to get it set up! While the tutorial uses the Pi 3B+, you can use the Pi 4 the exact same way. However, instead of a Pi 3B+ you will obviously need a Pi 4, instead of a Pi 3 Power Supply, you will need a Pi 4 Power Supply and instead of a HDMI cable, you will need a micro HDMI to HDMI cable.
