Hi Forum,
I am in need of using PI PICO 1 & 2 Boards, of using C Language, and was wondering for recommendations of how to setup for Creating C Files and compile to executable ie blick.uf2
I have Visual Studio Code installed, but yet to buy the PI Debugger Probe.
Also need to use PIO Code as well
I have found the the C/C++ SDK files and the Getting Started… and the example projects but do not know if it is the correct setup.
I need to be able to send and receive packets of up to 72 bits in length, and the reassemble the reply packet. Each packet has a min. of 5ms quiet between each packet. It is one way.
The idea is to create a low cost DCC Master station (model trains), and a separate DCC Packet Sniffer which decodes the packet. a Bit = 1 → 58us +/-3us Bit = 0 → 100us +/-5us.
I have the basics working in micropython - sending and receiving bits. Yes I am using PIO code in both the transmitter PICO V1 and the separate receiver PICO V1.
Any recommendations for setting up in C environment will be greatly appreciated.
Thanks,
Geoff Cole
As I assemble more code to reassemble the sent packetI fear that I mayt start missing sent bits
