Recently purchased
Gives, “PiicoDev could not communicate with module at address 0x35, check wiring”
from Read the PiicoDev Potentiometer value
from PiicoDev_Potentiometer import PiicoDev_Potentiometer
from PiicoDev_Unified import sleep_ms
and MicroPython v1.27.0 on 2025-12-09; Raspberry Pi Pico 2 W with RP2350
I2C scan does not find Potentiometer but others such as SSD1306 are found and work ok!
Check the potentiometer connection again. Check continuity of the jumper wires. If everything is OK but still the potentiometer is not working, probably you got a faulty product.
I got it working by setting the switches on the base of the pot from “0,0,0,0” to “1,0,0,0” and then
pot = PiicoDev_Potentiometer(minimum=0, maximum=1, d=[1,0,0,0]).
Cheers, Ken
Jane
16 February 2026 04:48
4
Glad you got it sorted, Ken.
