Hoping to use the DIY HDMI Cable Parts - Right Angle (R bend) HDMI Plug Adapter [ADA3549] and DIY HDMI Cable Parts - 10 cm HDMI Ribbon Cable [ADA3560] to terminate to my PCB .
As I am hoping to terminate this connector to another PCB, I am looking for the pinout/wiring for the ADA3549 ribbon cable connector?
Looked on the Adafruit website and Google but has not given me any results, so has anyone buzzed out the pins before?
Hi Daniel,
Welcome to the forum
Unfortunately, we haven’t received a pinout from Adafruit for that connector or any other documentation that would give you the pin mapping. Your best bet might be to map the connections out yourself using some fine-tipped multimeter probes in continuity mode.
Since all of the DIY HDMI cable parts are interchangeable you should only need to do it once and it should apply to all of the connector options.
