This is a placeholder topic for “HDMI Plug Breakout Board” comments.
Make your own custom HDMI cable or HDMI interface with ease, using this HDMI Plug to Breakout. You get a nice solid PCB with an HDMI plug and through hole pads that…
Read moreThis is a placeholder topic for “HDMI Plug Breakout Board” comments.
Read moreDo the solder holes on this breakout board have any specific purposes individually? For example ground, 5V or AV? Anything like that? If so is there a legend for this board I can look at?
hi @Jack229938 - welcome to the forums ![]()
Here the pins are just numbered 1-20 so you will have to refer to another pinout diagram to make sense of each pin’s purpose.
Here’s what I found after some light research
