This is a placeholder topic for “Pololu High-Power Motor Driver 18v15” comments.
This discrete MOSFET H-bridge motor driver enables bidirectional control of one high-power DC brushed motor. The little 1.3×0.8-inch board supports a wide 5.5 to 30 V voltage range and is efficient enough to deliver a continuous 15 A without a heat sink.
Hi! I was wondering whether this part (Pololu High-Power Motor Driver 18v15
SKU: POLOLU-755) can run two motors at once, from the one chip, or if it is only a single motor driver.
It’s an H -bridge, so if you only want to spin your motors in one direction then yes you should be able to do that, but if you want to reverse their direction you’ll need one driver per motor.
