I have a DAQ (OMB-DAQ-2408-2AO) which uses a USB-B to USB-A cable for power and signal delivery from and to the laptop. For my previous projects the, included, 1.5 metre long cable was sufficient. However, I need the DAQ to be 25 metres away from the pc/laptop.
How do I power and obtain signal from the DAQ over this distance?
I was thinking maybe using an adapter which converts the USB-B to RJ45 (over the 25 metres) then RJ45 back to USB-A which goes to the laptop?
25 metres is most definitely above the recommended 5m for a passive cable, you’d likely have to look towards a cable with an amplifier included, and while we don’t have any long enough, they aren’t too hard to find:
I’d also be prepared for the device to possibly not communicate flawlessly in this situation. Does it require USB3? or is 2.0 ok?
Is there any oppurtunity for a smaller SBC like a Raspberry Pi to be communicating the readings of the device over something more robust like ethernet?
Hi Zn
Have a look at RS485. I think there are RS485 to USB converters out there. Not sure about power maybe in the cable??. RS485 is supposed to be good for 1200M. It is a balanced line system.
