Hi community,
I am new to Arduino so I apologise if I’m making some rookie errors.
I have been following this youtube tutorial (see: How to connect a thermal printer to the Arduino | Small Project - YouTube) on printing from a 2nd hand thermal printer with Arduino.
I am using a TSC tdp-225 printer that works perfectly well when plugged in via USB to my laptop. It prints like a regular printer.
For my project, I want to connect it to my Arduino UNO (and eventually my ESP32 Fire Beetle) and print using Arduino commands. But, so far, I have been having difficulty.
Firstly, please see my circuit diagram. I am connecting the printer’s serial port via a D9 male to male adapter and RS232 Serial Converter. This is then connected to the Arduino UNO. All up, it is a pretty straightforward circuit.
The code I am using has been directly copy and pasted from the video. I can link this if you would like. In my opinion, a lot of the commands are superfluous at this stage. Something as simple as this (see below) should instruct the printer to print “Test”:
void setup() {
Serial.begin(9600);
Serial.println("Test");
void loop() {
I believe data is being transferred to the rs232 converter as its TX LED flashes whenever I press the reset button on the UNO. But, after that, nothing happens.
I have found this document (see: https://fs.tscprinters.com/system/files/31-0000001-00_tspl_tspl2_programming.pdf) which outlines the TSC programming language. I have tried using some of these commands (e.g. Serial.println(“SELFTEST”)) but also have had no luck. It simply won’t print.
I am pretty close to calling it quits and buying the Thermal Printer from the store here. I bet it’ll be a lot easier to work with.
Any help would be much appreciated!
Regards,
