I am having a problem getting gpsd to run with Adafruit Ultimate GPS HAT for Raspberry Pi. When I us gpsmon, I get the text below instead of the display I should be expecting:
tcp://localhost:2947 JSON slave driver>
(84) {“class”:“VERSION”,“release”:“3.16”,“rev”:“3.16-4”,“proto_major”:3,“proto_m
inor”:11}
(111) {“class”:“DEVICES”,“devices”:[{“class”:“DEVICE”,“path”:"/dev/ttyAMA0",“act
ivated”:“2018-09-26T03:39:53.326Z”}]}
(122) {“class”:“WATCH”,“enable”:true,“json”:false,“nmea”:false,“raw”:2,“scaled”:
false,“timing”:false,“split24”:false,“pps”:true}
I have also used cgps -s and get N/A for all feedback
When I use
stty -F /dev/serial0 raw 9600 cs8 clocal -cstopb
cat /dev/serial0
The raw data is showing a healthy signal.
I am not able to find out why the gpsd is not displaying readings.
If someone can help it would be very much appreciated
cheers Ian
