Hi Do you have a program for the SIM7600 CE from DFRobot. I need to be able to send text / sms to my number if a certain condition is met. I am using Arduino UNO.
Got to test with FONA _LTE test from Adafruit. If I can get that to work with my SIM7600 CE, thath will be good.
Regards,
Mthulisi
Hi Mthulisi,
You can find examples of how to use this device on the product wiki!
https://wiki.dfrobot.com/SIM7600CE-T_4G(LTE)_Shield_V1.0_SKU_TEL0124
Hi Stephen,
I have tried that. I can only call my gadget but I cannot make it too send text messages.
Regards,
I needed a more comprehensive code or library that can do that.
regards,
Mthulisi…
Hi Mthulisi,
Sorry but that is the best documentation that we have for this device!
Hi Stephen,
All I need in the mean time is someone who can while using that document available, to help me program the shield. That will be helpful if you can walk me through it.
Do you think you can help with that?
Mthulisi
Hi Mthulisi,
I can’t write code for you, but if you create some code and run into a bug, I can help you out with that!
Hi Stephen,
I don’t think I asked you to write the code.
Thanks mate
Mthulisi
I’m not sure what you are asking for then
Hi Steve,
Let us then draw lines of professionalism and leave it here.
Regards,
Mthulisi
I’ve tried to make a simple program according to this document. I want to be able to activate and read GPS data using SIM7600 CE from DFRobot and Arduino MEGA, but I still fail to get a response from the serial communication used.
Do you have a program for this solution?
Hi, what power supply are you using to power up the SIM module?
