Pulling specific data from a json string
Hi folks,
I’m trying to add a UV index to my weather station, being a Pico W running MicroPython.
I can get the json data ok but I’m struggling to break out the UVI number, being the first UVI number in the json string.
Insights appreciated!
# 9/3/25 - UVI from https://currentuvindex.com/api
# v1 - Get the json data.
# v2 - Extract the uvi number
import urequests # Network Request Module
import json  # JSON handling module
# Define the API endpoint and your API key
api_url = "https://currentuvindex.com/api/v1/uvi?"
api_key = ""  # Replace with your actual API key
# Define the latitude and longitude for Caloundra as got from https://latlong.info/australia/queensland/caloundra
latitude = -26.80346000
longitude = 153.12195000
# Construct the URL
request_url = f"{api_url}latitude={latitude}&longitude={longitude}"
print(request_url)
# Make the API request
response = urequests.get(request_url) # Send a GET request, the return type is the response of the request.
# Check if the request was successful
if response.status_code == 200:
    uvi_data = response.json()
    print("UVI Data:", uvi_data)
    print("Full UVI Data Response:")
    print(json.dumps(uvi_data))  # Print the entire JSON response.
    print(f'UVI: {uvi_data['uvi']}')
elif response.status_code == 400:
    print("Bad request. Please check your parameters and try again.")
elif response.status_code == 401:
    print("Unauthorized. Please check your API key.")
elif response.status_code == 404:
    print("Resource not found. Please check the URL.")
else:
    print("Failed to fetch UVI data. Status code:", response.status_code)
# Close the response to free up resources
response.close()
What is the json data that you are getting? What is the code you are using to convert the json data into a dictionary with the json.loads() method? That should return you a dictionary which you can use to lookup the UVI by label.
Hi @Mark285907
In the past I’ve used this to get time and date data from http://date.jsontest.com. Rather than using the json library I used ujson.
def fetch_text_from_website(site):
    response = urequests.get(site)
    data = ujson.loads(response.text)
    response.close()
    return data['date'], data['time']
You should be able to change the last line to suit the information that you’re getting from the site,
After a lot of self education and reading between the lines of various web pages re json and assumed knowledge…I’ve got it working.
The goal was to get the current UVI value for my location.
Happy for someone to point me to more elegant coding for unraveling the json string (attached).
>>> %Run -c $EDITOR_CONTENT
MPY: soft reboot
URL response is https://currentuvindex.com/api/v1/uvi?latitude=-26.80346&longitude=153.1219
UVI Data:
UVI Now: {'time': '2025-03-10T05:00:00Z', 'uvi': 0.8}
UVI Now Number: 0.8
import json
import ujson
# Construct the URL
print("URL response is " + request_url)
    uvi_data = response.json() # Write the response to the variable.
    print("UVI Data:", uvi_data) # Print same for testing.
    print(f'UVI Now: {uvi_data['now']}') # Print the "now" array for testing.
    uvi_data_now = uvi_data['now'] # Get the "now" array.
    uvi_data_now_value = uvi_data_now['uvi'] # Get the "uvi" key value.
    print("UVI Now Number: " + str(uvi_data_now_value)) # Print the "now", "uvi" key value.
else:
response.close()
json.pdf (51.8 KB)
Nice one! :partying_face:
