We have temperature from the sensor, but it would be good to know what the weather is like now from an Application Programming Interface (API).
Head over to the website: http://www.openweathermap.org to see for yourself what is information possible to achieve with micropython or any python code.
This is a fun bit of code to help you explore for yourself.
import urequests
import ujson
import utime
#time in unix time
def time_converter(time):
(year, month, mday, hour, minute, second, weekday, yearday) = utime.localtime(time)
return hour,minute,second
addr = ‘http://sample.openweathermap.org/data/2.5/weather?q=London,uk&appid=’
appid=‘b6907d289e10d714a6e88b30761fae22’
url = addr+appid
data_url = urequests.get(url)
utime.sleep(5)
data_line = data_url.text
data_url.close()
utime.sleep(5)
raw_api_dict = ujson.loads(data_line)
data = dict(city=raw_api_dict.get(‘name’),
country=raw_api_dict.get(‘sys’).get(‘country’),
temp=raw_api_dict.get(‘main’).get(‘temp’)- 273.15,
temp_max=raw_api_dict.get(‘main’).get(‘temp_max’)- 273.15,
temp_min=raw_api_dict.get(‘main’).get(‘temp_min’) - 273.15,
humidity=raw_api_dict.get(‘main’).get(‘humidity’),
pressure=raw_api_dict.get(‘main’).get(‘pressure’),
sky=raw_api_dict[‘weather’][0][‘main’],
sunrise=raw_api_dict.get(‘sys’).get(‘sunrise’),
sunset=raw_api_dict.get(‘sys’).get(‘sunset’),
wind=raw_api_dict.get(‘wind’).get(‘speed’),
wind_deg=raw_api_dict.get(‘deg’),
dt=raw_api_dict.get(‘dt’),
cloudiness=raw_api_dict.get(‘clouds’).get(‘all’)
m_symbol = ‘\xb0’ + ‘C’
print(’---------------------------------------’)
print(‘Current weather in: {}, {}:’.format(data[‘city’], data[‘country’]))
print(data[‘temp’], m_symbol, data[‘sky’])
print(‘Max: {}, Min: {}’.format(data[‘temp_max’], data[‘temp_min’]))
print(’’)
print(‘Wind Speed: {}, Degree: {}’.format(data[‘wind’], data[‘wind_deg’]))
print(‘Humidity: {}’.format(data[‘humidity’]))
print(‘Cloud: {}’.format(data[‘cloudiness’]))
print(‘Pressure: {}’.format(data[‘pressure’]))
(hour,minute,second) = time_converter(data[‘sunrise’])
print(‘Sunrise at: {0:02}:{1:02}:{2:02}’.format(hour,minute,second))
(hour,minute,second) = time_converter(data[‘sunset’])
print(‘Sunset at: {0:02}:{1:02}:{2:02}’.format(hour,minute,second))
print(’’)
(hour,minute,second) = time_converter(data[‘dt’])
print(‘Last update from the server: {0:02}:{1:02}:{2:02}’.format(hour,minute,second))
